EDIT TO CORRECT ALL OF MY MISGUIDED INITIAL THOUGHTS: The summit seats are crap for track and autocross use. Not that comfortable, didn’t hold me very well, feel cheap. Good maybe for drag racing. I went with sparco sprints, which are side mount capable and FIA certified. I went with RCI 5-point latch and link setup with swivel eyes for the harness ends. i welded a harness bar between the rear strut towers for my shoulder harnesses, but this is not ideal to the length. The jegs cage is not DOM, so it’s a no-go. Check out bdracing and kirk and autopower and rollcagecomponents for weld in cages. fire extinguishers should be mounted where they are easily reachable; my thought is to use the exhaust tunnel under where the radio used to sit. For more safety related details:
http://forums.g2ic.com/showthread.php?214883-92-RS-track-and-autocross-thread-with-build-pictures-amp-videos
I participate in advanced level track days and i want to get into time trials with NASA mid atlantic region. I also want to perform my modificatinos with future Honda Challenge H2 in mind. The car has basic suspension (camber, springs, dapmers, rear bar). brake (race pads, S.S. lines, DOT4 fluid), and engine (I/H/E) upgrades. It is also fairly stripped (around 2250lbs).
Here is what i have in mind for a safety setup:
I was looking at the Jegster roll cage, but it doesn’t use DOM tubing. Any bolt-in or weld-in cage recommendations? (i have a friend who can weld excellently, has welded chromoly chassis before)
Polyurethane racing seats OR Sparco/Corbeau/ect upholstered seat (realize that non SFI seats will require a back brace for HC)
http://www.summitracing.com/parts/rci-8000s/overview/ (RCI and summit both have versions of poly seat) -
5-point harness with 3" straps. I would like recommendations on mounting (wraparound rollbar mounting vs bolt to rear seat spot), latch vs. cam, brands, ect.
Extinguisher mounted under passenger seat
Moving up from track days to time trials & door-to-door is a big step for me; I appreciate the advice.
