shaking around 1k-3k rpms
hello… I recently picked up a 90 RS and under acceleration I feel shaking coming from the front driverside corner.( dont really feel it after 3grand)Now i have new pads and rotors and freshly mounted and balanced tires. When i jack the car up and shake the driverside front wheel it moves back and forth a little left and right. Is this the tie rod could it be causing the shaking under acceleration? Axles look good no clicking or rips in the boots.
Thanks for the help in advance
John
hmm just driving it now and it doesnt seem to do it really around corners…
feels almost like a wheel hop feel … after 3k dont notice it
Check ur axles
well… Axles both look fine no tears or rips in the boots… and no clicking on turns
and it doesnt do it if i hold it at a constant rpm… i know the tierod end is bad so could this be the cause
try checking yoru tire pressure…
