I just got my teg’s front left brake rotor a few days ago after it got scratched badly from a wasted brakepad. Now when braking my steering wheel shakes a little bit now. It wasnt like that before i had it resurfaced. Does someone here know whats happening here? Is it the alignment? One thing i noticed is that when I look in front of the car my left tire seems to look like its kinda longer i mean i can see the tires thread easily than the right side. Like its kinda extended. Sounds weird but need to know whats causing the steering wheel shake when braking.
Well,
The other rotors could be warped. What exactly did you do other than resurface your left front rotor? Any noise when driving? How does the brake pedal feel when braking? Are you sure the left front rotor is bolted on properly to the axle?
About your tires, did you put your tires the way they were before you took them out? Used the same bolts, no spacers added?
BTW, brake service doesn’t fudge the alignment…unless coincidentally, your alignment went capoof when you got your brakes done.
Regards,
Oz
