Ive got a 90RS with the janky non-powered antenna. I plugged the whole and want to use the radio still. I bought the hidden antenna from Autoloc and it’s crap. I get no signal unless the excess wires are hanging outside the car. However, after reading a post i think maybe the ground is not very good (which it isn’t, didn’t know that it had to be a super great ground). WHAT DO YOU GUYS THINK HERE??
My other solution is using the antenna from newer accords. They are hidden but its some sort of module, that has to be grounded, an antenna wire with extra plugs at each end and it looks like the module has an extra plug(i dont know where that goes). So if anyone knew or could enlighten me on any of these options or maybe suggest a better way and still keep clean lines. (i.e. - no fuba)…i’d appreciate it. Thanks
man if you had posted this like 10 min earlyer. i just got the autolock hidden antenna. i hope i have better luck than you. try redoing the ground and post up what happens
sure will man, give me about 3-4 hours from now…still at work im probably going to move the antenna around a bit. Right now it is on the back glass. I’ll keep ya informed.
