Shaving OEM side molding to JDM moldings
Has anyone tried shaving down the side OEM moldings to make them resemble JDM moldings? you could paint them after for the gsr look.
http://ep.yimg.com/ca/I/yhst-1408381693991_2237_25663334
guessing they are not solid, so you couldn’t remove enough material to do what you are asking without ruining them.
with the work involved even if they are solid, think i would just get jdm if that’s what you want.
what ^^^ said…
and no they are not solid. they are only about 1/4" thick _/ shaped with plastic clips holding them to the body
I have. Because they have that angled shape, when you shave them down they become shorter top to bottom and don’t look right against the body line. Then you still have to use the fender molding type clips for all 3 of the moldings and permanently attach them in the correct place to hold them on. Its not rocket science or a ton of work but its never going to come out close to as good as the jdm moldings look.
I hate usdm moldings.
