Short throw shifter problem
I was sold a short throw shifter from a buddy and installed it. Works great, throw is real short but rattles on my exhaust. I was wondering if anyone else has had this problem. Oh yea, its stock exhaust too.
Happened to mine tooo its jus the bottom of the shifter bar hitting the heat sheild and rattling it…what i did is bend the heat sheild a lil so it doesnt touch itt…
ok thanks ill try that
very common problem, most people just remove the heat shield or bend it as mentioned.
do you think it will go away or get worse when i put new exhaust on?
well mine used to rub across the top of the exaust and at idle I would just hold the shifter over to the left so it would annoy the piss out of me, so im gonna say YES. there are things you can do to combat it. try to finda set of longer exaust hangers and maybe your can get just enough clearance.
