I dont think DA and DC shifters are interchangable.
Yes you can do an ITR shift linkage and b&m shifter, just buy the b&m for the ITR. But honestly, the ITR shifter is short and solid, and better than the b&m. Every person that sat in my car felt the shifter and were in love with it.
well… it’s not a matter of which is better all the time, sometimes it’s that we already have the b&m shifter, or any other shifter that we used to have… and we dont have the extra cash to put out for the shifter along with it…
No, there is no modification needed. Its a direct replacement.
You can also use any DC2 shift linkage. Its the same as the ITR except the JDM ITR is zinc plated (gold color). What makes the HUGE difference is the ITR shifter itself. Its short, its OEM, and its dual bent meaning it sits closer to you (driver) allowing for easier shifting. You have to feel one to see the difference versus a stock shift linkage, and aftermarket shifter.
I have driven an integra with ITR linkage, but a b&m shifter in it, and it was not a good feeling at all. This is my opinion.
So a B&M shifter with the ITR shift linkage isn’t really worth it. I am assuming that the B&M ITR shifter doesn’t have the dual bend to sit it closer to the driver?
i just removed my shift linkage to install the bushing etc, and noticed the little thing at the end of the lnkage was loose and nasty, plus the welded joints are all rusty so, youre 100% sure the linakges are the same? i know about the shift lever.
You NEED to call stores where they sell jdm stuff, especially motors. Try:
inlinefour
jhpusa
passwordjdm
hmotorsonline
k wantanbe
h auto dismantlers [714-554-7657] <—strictly honda/acura dismantlers. Have a huge warehouse of shit!!!
Most of these stores wont list it on their sites, but some have one here and there.
From what I’ve read the Itr shift linkage is the same as the DC linkage, except that the itr is zinc plated? So basically all I need to do is find a DC linkage and combine that with the ITR shifter? I’m sure that would be much easier to find. And this will give the same results as if I had the itr linkage because they are the same otherwise, correct?
Also if u have a picture of how the shifter used to sit in the interior please email it to me
Also, I used to have a picture of it in my car, but this was many years ago, and I havent been able to find it. If I come across it, i’ll let you know.
I have a DC2 ITR shifter with ES bushings in my DA. All I had to do to make it fit my stock DA shift linkage was to grind about 4mm off of the base and it fit right in. YOU DON’T HAVE TO BUY ITR SHIFT LINKAGE!!!
Sweet. I was thinking of passing on this mod because of the rarity/price of ITR linkage but if any gen3 linkage is basically the same, then that opens up a lot of doors.
PS- to anyone thinking of doing this, if you search there is a pic of a gen2 vs gen3 shifter, and it says which ~4mm you have to grind off, like knowledge said.
It’s seriously SUCH an easy mod to put a DC2 shifter into a DA. I would recommend it to everyone. You don’t necessarily have to get an ITR shifter, as I’m coming to the conclusion that the ITR shifter is just a polished GS-R shifter. Either way, the DC2 shifter makes for the perfect throw IMO.
I got my shifter used off ebay for $20 shipped. Best mod for the money I’ve ever done. No linkage or any other parts necessary.
FUCK A SHORT SHIFTER!!! It’s a waste of money…OEM HONDA BABY!!!
