Shudders Upon Takeoff
Hey guys i just started having this problem when i got to let out the clutch the car shudders as if its gonna die then keep going smooth
Its a b20v with ys1 ls trans stock clutch i just dont know where to start. could it be a trans problem or is it something more simple
thanks in advance guys:)
sounds like a slipping clutch…check your clutch disc
yep thats what it was. clutch broke
I am experiencing a similar problem. I changed driver side wheel bearing, axle and half shaft. At the same I had a new clutch put in as well. When I take off on first gear I feel a vibration, it feels like it does it the most when I turn to the right. When I go over a bump it seems to vibrate harder. I am gonna check that passenger side axle and suspension on the passenger side for trouble. I hope its not the new clutch because I will have to drop that thing again. I have not done an alinement on the car but I don’t think it will do that even if I did not. IDK??
It turned out being my engine mounts, driver side wheel bearing, front driver side blown F2 shock. But I am still getting vibration front the front when a hit a dip. I think it could possibly be the other side of F2 shock or axle…IdK…
