My car is making a shooshing/swirling type noise when turning r
right. Anyone know what this could be. No cliciking and the CV boots look fine.
most likely power steering. Could check belt tension and/or fluid. If it is power steering and belt tension and fluid level is fine, might have to deal w/it or replace pump.
Same problem here, I used to notice it in the morning when it was cold outside. Tonight it was really bad. I need to remember to check fluids tommorow morning, the belts are pretty new and I think the tension should also be good. Hey, I am not damaging anything if it is low fluid?
More than likely its your power streering. Check fluids and belts.
What part of Kennesaw you from G2stylee? Ever hit Barrett Starbucks on the weekends?
I grabbed some psf from a gas station. Now the noise isn’t as bad but sometimes there is a little swoosh. I noticed in the helms manual that it tells us to only use honda PSF. Can I drain the fluid that is in there and then replace? Is this a good idea and why?
Also, how many of you are “honda only”?
