Can anyone confirm that the SI 15" wheels will fit after the Legend brake upgrade? I’ve read a lot and haven’t found any definitive answer; most people say it will fit SOME 15" wheels and ‘should’ fit OEM wheels. But I need to be certain before I go ahead with this…
ok, my answer is not definitive, but i’m saying they should fit. sorry, but i know that’s not the answer you want to hear lol
The reason i said they SHOULD fit is that I’m running NSX front calipers which is essentially similar to the legend front calipers, and I had gsr “hammers” (5spoke 15’‘s) and they cleared the calipers fine, and I also ran a set of some 5zigen 15’’ wheels and they also cleared the brakes as well, just barely. That being said, a SI rim should fit in my mind… the only problem I encountered was the brake shield rubbing against the rotor, but that was an easy fix. Hope this can help guide you in the right direction! Good Luck!
