nahh the turn signals doesnt stay on when the turnsignals arnt blinking (im pretty sure)… how it works is that theres 2 bulbs one close to the front and one behind the orange. the one behind the orange is the blinker (turn signal ) and the one more to the front of the car is the constant (parking light: first click before the low beams) if the blinkers (turn signals) arent on then that entire bulb stays off… and the staying on your probably thinking of is from the constant (parking light)
Unless someone can prove me wrong… i should run to my car and check…
Just went out and checked. Atleast on my 93 Teg the amber marker lights up on the USDM corners even when you just have the parking lights on and are not signalling. I thought so. So that makes things really simple to wire since that bulb is not used in the JDMs.
PS: Mods…might want to consider moving this to the Electrical section.
you know i did what you are talking about with my da i made the corners ands side markers stay on as parking lights and they also signal. you will have to relay the side markers to do this because the wires at the parking light is permanently grouned. meaning if u hook up 2 power souces there just gonna ground out because of the way the factory circut is. its hard to explain il take some pics this weekend while i wire my foglights
