side markers question?
so just wired up side markers on both sides to the amber head light turn signals. then i decided that it was a good idea to also wire them up to the bumper signals so they would blink and stay on at the same time. BAD IDEA! i think i fried the wire. so the side markers dont work on one side. any ideas to what it could be. checked the fuses and everything is good there. possibly relay?
First, disconnect the wire that you used to splice into the existing wiring (at the splice). See if anything works. You probably sent the 12 volts on that circuit straight to ground.
already tried that right after still no power to the side marker or the corner light? ???
The front side markers, [next to head lights] are controlled by the ICU, if they no longer work you have probably blown the ICU.
Do the front signal lights, [bumper lights] still work?94
