Sincros
could anyone tell me how much it would cost me to get this grinding fix. if too much im thinking of selling.
probably cheaper just to find a new used LS tranny instead of replacing synchro’s.
Tegon:
If your referring to the 3rd gear synchro set its about $280.00 for the set + Labor…
J.
J, what does the 4th gear set go for? :slight_smile:
Redline: $95.00 list…
J.
Thanks … how come so much cheaper?
Steve
Redline:
Basically…because you can’t just buy the 3rd gear, you must also buy the rings and other necessary parts on the main shaft. If just the 3rd gear was available I’m sure it would be similar in price.
J.
Ohhhh, I get it … thanks for the info!
hey, how much u think it would be for them to replace my first 4 gears with b16a gears and just leave my 5th gear alone?
Mr X:
I assuming you still have the original YS1 trans(LS), and if thats the case(pun intended), the syncros in a B16(JDM) are not compatiable with USDM YS1. Every B-series trans after the non-obd B16s are interchangeable with each other; including type Rs.
HTH,
J.
hey J
is it possible to swap in the LS 5th gear into the b16a tranny? if so how much would that cost>?
also does anybody know the topspeed on the b16a 5th gear?
gt:
No, to my knowledge(which has been wrong before), you can’t swap in a USDM 5th gear into an JDM B16 trans. The gears are cut completly different. There is a taller JDM 5th which can be used, but I’m not sure of its origin. Generally an experienced mechanic will charge 300 to drop and re-install the case, and about 250 to actually do any kind of “in case” work. So, not cheap!
HTH,
J.
Good tranny advice in here. archivethis
