I installed Skunk2 Upper control arms… anyways I have this horrible squeak when i go over bumps. I didnt have it at first, but now it is developing and getting worse. Was I supposed to grease something???
I have skunk 2 upper control arms
energy suspension balljoint boots
energy suspension upper shock bushings
ES sway bar bushings
Did you preload the control arms before torqueing everything to spec? If you didn’t, the squeaking might be caused by the rubber binding or twisting. Also, a lot of aftermarket suspension parts use cheap rubber so they tend to squeak unless you grease them with the appropriate lubricants…
yeah preloading them, pretty much so they’re in the position their in with the cars weight on them, also its a good idea to use so grease on the bushings it’ll prolong the life a little and help with squeaking
Yeah like what “most envd” said. Easiest way to do it is to have the front on jack stands, tightened everything loosely up by hand, then with a jack placed underneath the lca, jack it up till it’s the same height as your car would be on the ground then torque all the bolts to spec… hope I didn’t confuse you.
No man, sounds good. I have a set of ES bushings I might install instead. Im sure Skunk2 and ES bushings are about the same quality but I like prefer red. Its just a hassle losening the bolts for the control arms off. NO room to work with.
