skunk upper arms issue
ok so i have tokiko blue shocks with neespeed yellow race springs just put on the z10 front member and skunk upper pro arms the camber adj is maxed out and iam still -1.32 off now the box these came in was missing the part # so can these be the wrong arms maby to short also the wheel looks to be pushed back not centerd in the wheel well the caster looks right on paper but the wheel was centerd befor with stock member at 65mph car shakes what do u think thanks
Definetly an allignment problem, it is always reccomended to get your wheels realligned at a shop (unless you know how to do it yourself) but with the new front "cross"member im assuming, did it come with adjustable tie rods(toe)? because that may be the reason why your wheels seem off center in the wheel well. And camber can only be corrected +/- 5 degrees. -1.32 isnt all bad… But for sure check your caster and toe for the shaking at 65mph.
