I have a very slight wobble in both of my front tires, but moreso on the passenger side. Anyhow, when i had the car jacked up yesterday, I was able to wobble the tire very very slightly side-to-side. There is absolutely no up/down wobble. I know this means the tie-rod ends are wearing out, although one was replaced literally 2 months ago.
Anyhow, being a VERY slight wobble (we’re talking total wobble of about 1/16" or even only 1/32" or so), is this really bad or can it be left alone for now? I’d rather not replace both tie rod ends as they run up the monthly maintenance bill ($35/each + labour from a friend).
Also, on a somewhat related note, do I need an alignment after replacing the Lower Ball Joint on my drivers’ side?
leave it for now, but definitely keep an eye on things and when it gets worse, it’s time to replace 'em. you should be okay for a little while though as long as you’re not tracking the car.
