smoke from under my dash.
My car didnt want to start so i figured i should hit the main fuel relay around so i banged under my dash. Did not work. So the car just clicks when i turn the key and the car doesnt crank. So i held the key in the start position for about 5 seconds to try to start it. Then some smoke came out from under the dash. any suggestions?
Look under the dash for any parts that was burning.
will do asson as i get to the garage
The engine main ground was bad so i put a bigger cable so it cranks now and doesnt start. am gonna mess with it more tomorrow to see if i can get it to start.
Had the same problem. Check all grounds. I was missing two of them. Chassis to tranny chassis to valve cover, ground on top of thermostat and check condition of wires.
thing is I drove the car after putting the motor in 3 times and now it is not turning over. I am gonna check my grounds again.
grounds was the problem. problem fixed
THanxs alot guys
