So let me get this straight (fuel issues)
Car is not getting any fuel pressure. No priming sound, no clicks under dash. Cranks just fine.
Checked:
Fuse 18-good
Underhood fuse 38-good
Fuse 24-good
So if I’ve researched correctly, there is a connector at the sending unit under the rear seat, if I get power there then the pump is dead. If I get nothing the relay is dead right?
Main Fuel Relay (MFR) could be the problem, yes.
when you cycle the key on, does the CEL come on briefly?
