Socal- FS: semi complete built ls/vtec
i am selling an almost complete ls/vtec…
b18b1 block 82mm
b18c1 water pump
b18c1 oil pump
b18b1 micropolished knifeedged crankshaft
king main engine bearings bnib
b18b1 oil pan
cylinders honed and bored 1mm over
just missing rods/pistons/rod bolts
b16a1 head
milled for higher compression
b18c5 valvesprings
titanium retainers
b18c1 camshafts
b16 camgears
b16 fuel rail
b16 fuel injectors
b16 valve cover
all necessary bolts for both bottom and top end
may be getting type r pistons to add to bunch and some more stuff in the next week or so
can sell complete head seperately or block as it is seperately but no individual part outs…
id like 450 for block and 500 for head… can do both for 850 picked up… like i said i may be getting more parts like intake manifold/pistons/etc etc but then price will go up…
prices are firm no lowballers or trades unless its for h2b kit, s300, b16 tranny, but no appearance parts or cosmetics…
i also have a ls and b20 intake manifold for 50 bucks each…
everything is in good condition and tooken apart so you can check yourself if needed… thanks for looking.
bump… someones gotta be building a motor or wants to build a motor on here… parts are in excellent condition. low miles. oil pump and water pump are 0 miles… bearings are 0 miles… block and crank has less than 500 miles… head has less than 500 miles… taken apart so you can check parts to see for yourself, i took it apart to fully build but plans have changed so would like to sell.
What condition is your VC in? Trade + cash?
