Some one with a b18c1 service manual/knowledge help me out
I’m putting my b18c1 back together and want to make sure all my clearances are correct. I have been using my 92 Acura Service manual and the clearances for the b17A engine. If you have a service manual for the b18c can you check these for me
Main Bearings
1,2,4,5 = .024-.042mm
3 = .03-.048mm
Rod Bearings
.032-.050mm
Thanks ahead of time.
main bearings=
1,2,4 and 5 journals 0.024 - 0.042
service limit 0.050
no.3 journal 0.030 - 0.048
service limit 0.060
rod bearings=
0.032 - 0.050
service limit 0.060
HTH
ps i just copied that direct from the 1995 service manual.
yeah that did help g2gsr. Did you see this post in the general discussion or in the hybrid forum?
