some questions about b20 swap
i am thinking to swap the motor between type r and b20
i am not considering h22 and k, i think it will be too much hassle for me being a noob
i dont go over 4k rpm, so i am gussing vtec will be useless for me, would b20 be the best bet for a nice relliable daliay car?
since i am in cali,i wanna do the swap right, i wanna smog it, if i do the b20 swap i will shave the stamp, and figure out a way to restamp the b18a1 on it
what i want is no one can tell there is a b20
my question is would the tech at test station know the car is odb1 or odb2 ? and are there any other visual differences between b20 and b18 besides the stamp, intake mani?
would full intake , full exhaust take me to 170-180 whp, 150+ torque with a hondata turnd b20 , or maybe 160hp ?
i will get a 99+ b20b jdm or usdm 20z, i think it will come with an ecu, will i be odb1 or odb2 with the ecu comes with the b20?
would it fail smog test with everything i have and tuened with a hondata?
i think it shouldnt be failling cuz i got a newer healther mortor, but i heard some cars are turned too aggressive, so it wouldnt pass
as for the tranny, i heard the ls tranny is good for b20. which tranny is the best?
and i always wondered ,
what are the differences of the intake mani from vtec to none vtec?
thanks guys :rockon:
:rockon: come on guys , give me a hand here.
My vote is for a B16 actually, perhaps with a tranny like an Ls. very light motor, great mpg, but still enough “mustard” so you can pass people ya dig? hmotorsonline.com has b16’s for super cheap, and in absolutely mint condition. Give it a look see, if not that, I vote a gsr.
i dont know man , i kinda made up my mind already,i dont rev hard , i heard b16 is good only if you rev high.
ive heard a lota good things about a b20. for both price and performance a b16 cant beat a b20, and it cost $150 more, i could use $150 a nice used skunk2 intake or a dc header.
for the weight of b motors i really have no idea, all i know is they are all light weight compare to h and k:D
hopfully i got all my questions answered , i can finish the swap next year
i really dont wanna fail the smog check , or get pulled over then happen to have to swap the motor back to be legal
cali really sucks
thanks for the input man, hmotorsonline.com is a really good site.
i remeber you telling me that you wanted something smogged legal. with the b20 you won’t be able to B.A.R. the motor(illegal) and the b18c5(type-r) motor is more on the expensive side and hard to find locally. my suggestion is just drop both choices of motors and go with a USDM GSR motor… preferably a b18c1 over the b17a1(those are a little harder to find with low millage). believe me…you won’t be disappointed with a gsr motor, both torque and high horse powerwhen you need it. it’s pretty common to find a gsr motor locally(since you being a noob in all…i suggest to find a motor that in your area…no ebay crap). it’s also good because ur cable LS transmission will be a decent mate with the gs-r motor…unless you find a good b16 ys1 cable tranny or get the complete gsr swap (i.e. motor, tranny, axles, ecu, everything) and just get the cable to hyro kit…with that extra money you’ll be saving from NOT buying a type-r motor.
that’s just my 2 cents.
k series is lighter than B series
also who doesnt rev there car part 4k?
Your askin that you want to swap but you dont seem to be doin it for any reason, so why not just stick with the LS?
in cali huh?
b20 = illegal. honda tagged it as a “small suv” engine, so you cant use it. since its a b-series though, you might get away with it as some smog shops dont check the engine code since its similar in look. however, get it checked once or get your hood popped and your fried.
b18c5 = you better carry your papers at all times. this engine will also require a obd2+ conversion. as there was no obd1 hype-r for you to say you upgraded to. you will also need to first find a legit swap, if looking for usdm, in cali. which is very very hard to do. remember that the block will have the vin tag on it so a legit source will be required if you want to keep cali from crushing the car.
b18a = direct swap and the least hassles with anyone.
b18b = direct swap and less hassles with anyone (might get a look or two if its a obd2 block). since its a direct replacement engine, you dont have to convert the obd system.
b16a/x = will require a ref. have to be obd1 and finding a usdm p30 is hard/expensive.
I have a 91 with b20z. I traded an old h22 head for it. It had 100k with sunken valves in the head. I put my b18a head b20z cams and ls intake on. The car is an automatic and has plenty of power for a daily drivers and loads of torque even spins alittle in 2nd. My 2 cents is get a b20z and drop it in.
why you guys say b18c5, aint it b18c in japan, i dont want usdm motor, not they are worse, mileage of used usdm motors is a ? most jdm motors ive seen on internet are clean, when the valve cover is off , you can see the head is hella clean.
what i read from dmv website, you can get any motor thats newer bar’d as long as it passes smog and not a truck motor
i dont go over 4k rpm cuz , my 4th gear grinds sometimes around that rpm
i think shift over 4-5 k , you kinda abuse the motor and tranny, i want the car to be reliable. i dont know about you guys.
i did a lot resaerch , i already compared all the b motors , i even compared the dyno sheets of all the motors, denpending on my driving style i decided to go with b20, most people have had both gsr and b20 state that b20 could easily walk a gsr, but the con of a b20 is it has less power at high rpm
if i am knowledgeable enough , i will def go with h22, its cheaper, more power and more torque
type r front clip cost around 5000 shipped
type r lsd swap 3500-4000 shipped
gsr lsd swap 2700- 3000 shipped
99+ b20 motor 900 shipped
s80 lsd tranny cost 1000+ shipped
for me right now , if i can make the b20 looks just like ls i will do it , otherwise i will do type r , i will just get a full swap since my tranny is getting old , type r has a hand build head, it cost not more than a 1000 to gsr, it has 30 more hp , you cant get 30 hp from a gsr motor for 1000
pls read , i said i will shave the engine code, i will buy the stamp they use to stamp the eninge from my country, restamp b18a1 and whatever the other numbers under the b18a1
so far no one really answered my questions, i really made up my mind already , b20 or type r full swap. dont say that type r is hard to find,there are a lot typr motors out there if you have 4000 dollars
[QUOTE=coke;2094615]why you guys say b18c5, aint it b18c in japan, i dont want usdm motor, not they are worse, mileage of used usdm motors is a ? most jdm motors ive seen on internet are clean, when the valve cover is off , you can see the head is hella clean.[/QUOTE]1) the donation of the “5” after the “C” is to make sure its clear that we are speaking about the hype-r engine.
  1. under the VC doesnt tell you anything. a little brake cleaner can go a long way when taking a pic.
  2. the b18b1 i have under the hood of my db1 lasted 54.1 miles before it spun a rod bearing when i picked it up. under the vc was perfect, just saying…
[QUOTE=coke;2094615]what i read from dmv website, you can get any motor thats newer bar’d as long as it passes smog and not a truck motor[/QUOTE]i suggest you call a ref. you can pass a new engine. however, for certain engines you will be required to update the engine management system. the type-r is only legal wth the type-r USDM ecu. doesnt matter where the engine came from, only the ecu matters (to california).
[QUOTE=coke;2094615]i did a lot resaerch , i already compared all the b motors , i even compared the dyno sheets of all the motors, denpending on my driving style i decided to go with b20, most people have had both gsr and b20 state that b20 could easily walk a gsr, but the con of a b20 is it has less power at high rpm[/QUOTE]a b20 would not “walk” a gsr. not possible unless gearing was changed between them. the b20, at best, would keep with a gsr if the transmission was the same. i would like to know where you did the “research”, cause it seems a little faulty to me.
[QUOTE=coke;2094615]for me right now , if i can make the b20 looks just like ls i will do it , otherwise i will do type r , i will just get a full swap since my tranny is getting old , type r has a hand build head, it cost not more than a 1000 to gsr, it has 30 more hp , you cant get 30 hp from a gsr motor for 1000[/QUOTE]1) the b20 looks similar, once the manifolds are swapped to the ls stuff. however, it will not smog like a b18.
  1. the type-r (hype-r) is not hand built, its hand ported. but its just a minor clean up really. the main thing about the hype-r is the rarity of the swap, the ecu map, the cams, intake manifold, and header. after that, its really just an over priced gsr.
  2. if you only get 30 whp for 1k spent (on any engine), you need to rethink some things…
[QUOTE=coke;2094615]pls read , i said i will shave the engine code, i will buy the stamp they use to stamp the engine from my country, re-stamp b18a1 and whatever the other numbers under the b18a1[/QUOTE]re-stamping is fine, but realize that if you dont do it perfect that your screwed. to be honest, i am trying to help you from making a huge mistake. if you get caught, your car will be crushed. is it worth the issues to have .2 liters more displacement?
[QUOTE=coke;2094615]so far no one really answered my questions, i really made up my mind already , b20 or type r full swap. dont say that type r is hard to find,there are a lot typr motors out there if you have 4000 dollars[/QUOTE]1) yes, there is a way to know if the ecu is obd0/1/2a/2b. there is a stamp date on the ecu. the base code for the ecu is also known to most stations/refs. honda swaps are not uncommon. depending on your area (like san jose), your going to have to be perfect to get away with what your planning on doing with a b20.
  1. the sniffer will tell the tech if the engine is a b20 or not. the b20 isnt efficient enough. if you made it more efficient, it might get away.
  2. lastly, it seems as if you already made up your mind on what you think you can get away with. right now, i wouldnt test the california laws with trying to pass anything under the radar unless your 100% use its going to pass. till 2002, i was in california. i was born and raised there, and have seen the import scene changes in the bay area. i wouldnt risk my car simply to be one of the cool guys with a b20. especially since the b18 is better in regards to daily use. the possibility of a b18c5 (or b18c since your so hard up for the lack of a single number) swap that is done correctly is probably out of your ability. for the 4k, your getting a engine, trans (which you cant just bolt in) and ecu (which is useless to you, if the ecu is jdm).
wow, seriously man. you really answered all my questions.
you really changed my whole idea, thanks for your time to help me
after what you said, i think i will just get a gsr once everything in my life settles down next year. so can i get a jdm full gsr swap bard?
i miss looked a lot things tho, you can make a 30 hp to crank easily by bolt ons and cams for around 1000, maybe even 30 to wheels. i was confused cuz b20 cost 5 6 hundred lesser, people been saying it can keep up with gsr
and seems like everyone is telling me to get a gsr.
i finally get why its that now
how is a gsr compare to a ls when you shift around 4000 rpm. does it feel like a lot faster?
i always wondered for those people who shift above 5k-6k, how long would the motor last? for me , i change oil every 3500 miles with castrol synthetic , i use chevron 91 all the ime. i think my ls will last 300k miles till it burns a lot oil
i hope you understand that i just want more power, i love DA integras
but people always look down at these old hondas, i can tell people look down at me, everytime when i see the look of those people who are in a bmw , subaru and evo, or pricks in a 2008 ford with a v6 try to get me to race them, just because i drive a honda and its been modified, those people kinda pick on us, you dig? sometimes i just wanna rev the shit up, and smoke those motherfuckers, but the truth is the ls cant beat a v6
i hope you can feel how i feel
again, thanks a lot man
we should meet up when you come back to cali
A b20z2 is about a grand these days with low miledge, they with bolt ons will keep up to a stock GSR. But your in cali so dont even think twice about a B20 unless its just a drag car.
GSR’s are great engines. Not very impressive untill you hit vtec, Under vtec dont seem all that faster then an LS.
Im not much of a racer but our cars will beat lots of v6’s and some v8’s. But most of those are not made for speed, just morso to move the heavy car or truck.
Get a B18b 145 hp 127 torque obd1 from what I have heard and it will be a legal swap.
yeah I did some looking into the b20 swap and called the state reff in cali and was told a b20 swap was illegal in cali and I would have a beeter chance with a H22 swap only cuz it comes out of a 2dr passanger car not an SUV. Also what ever engine you get at the end it would make sense to complete it with a b16 tranny. Now days you can find a b16 tranny with LSD for about $300-$400 and the gears for the LS motor are perfect. You have all the good low torque and the short gears of the b16 to get you moving fast. I have the b16 Y1 lsd tranny from a si del sol and its like driving a completly new hot rod.
