Some questions
ok, here is my problem, In my car, the light on the ceiling is ALWAYS on and all the doors are closed. why is it always on>?? there are 3 options on the switch which are, like always on, doors, and off. when you put in on doors, when you close the hatch, and doors, that light should go off, but for me it’s still on.
is it hard to install JDM headlights??? I heard you need to extend some cables to connect to the JDM headlights?? and can u use normal light bulbs?? or do you need special ones???
and will ITR suspension(struts and springs) work on a 1990 Acura integra RS???
Could be a bad contact on one of those sensors on the door jam.
for the door, check that black L shape thing by the door. u can see it when the door is open. see if u can push both side (pass/driver) in and see if it goes off. u probably need some tape over it to make it thicker. thats what i did. for the JDM lights u just need to rewire the connectors and it uses H4H bulbs but u can use regular H4 with minor adjustment.
how hard is it to rewire the connectors???
