Well, i was woundering why my teg is soo HOT. When it is hot out, and am cruising, ill have my fan off, but some air will still blow threw the vents. I was woundering why the air is so damme Hot. should the air be some what cool . just woundering cause no other car that am inn gets soo HOT.
if you’ve got hot air outside, open vents inside, it’s obvious you’re gonna get hot air inside. if you’ve got an RS slide the slider postiong to recirculate. if you’ve got an LS GS GS-R push the recirculate button. OR turn on the A/C. and the only reason why you would get cold air instead of hot air is if it’s really cold outside and you have the “fresh air selection” selected.
Could also be that you are stuck in the heat position. In other words your heater is partially on because the cable has slipped and can’t turn the heater off.
