Sparco Torinos
Hello Forum,
I am having a problem with fitting my Torinos into my teg. The seat belt mount on the base makes it so that I can’t bolt the seat belt housing to the mount because it hits the knob on the seat. The only way i can make it fit is by moving the seat belt housing foward so it doesn’t hit the knob and only bolting the back bolt on to the mount. Plus I have to have the seat at the highest setting so it can fit in my car because the seat belt housing position won’t let allow a lower setting cause the knob hits.
I have searched the forum and most people go custom brackets. I was wondering if there is a way to make the seat belt housing bolt up in a way so i can put my seat and the lowest setting. I just want to be able to enjoy my seats. Any help or advice would be appreciated. Thanks
I have the milanos and my problem was that I can’t slide my seat forward without hitting the knob. Luckily I am over 6 feet tall so this isn’t that much of a problem. I can’t remember if the universal mounts mattered which way you mount them, but maybe try flipping them back to front? Also the knob pulls right off…
Good luck!
-Keith
Thanks for the response. I will play with the mounts to see it helps and I guess if that doesn’t work I can just pull the knob off. Thanks a lot
