Spark Plugs
the fourth one has oil ? is that normal?
Oil where?
On top of the threads where the spark plug boot plugs on to?
On the electrode?
Normally, oil is not supposed to be present on spark plugs.
take off the valve cover and take a look at your gaskets, you might need to replace them.
It depends on if it is leaking from there.
Until he tells us where the oil is, there is no point in giving a solution.
its where my spark plug is. theres a little pool of oil in it.
So it’s on top of the spark plug where the spark plug wire plugs into?
If so, then it is the spark plug o-rings.
alright. where could i get that and how much do you think those are?
Call the dealer and/or auto parts store and ask.
how would i get the oil out of there?
I’m sure you can figure out on your own how to clean it out.
