What are the best sparkplugs to use for 2nd gernation integras? I’ve been using factory one from honda for the longest time and I want to try someting new.
N G K
NGK are the factory issued ones.
But I’ve heard you get the bext ignition parts from the dealer unless you plan on upgrading to higher quality parts.
I personally just use what the dealer has, an it’s cheaper then going to Canadian Tire or whatever to get spark plugs.
Don’t forget to gap them correctly.
Originally posted by SerialOne
[B]NGK are the factory issued ones.
I personally just use what the dealer has, an it’s cheaper then going to Canadian Tire or whatever to get spark plugs. [/B]
HONDA FACTORY=NGK
OE NGK or aftermarket NGK?
What do you mean by gaping them correctly?
stock gap is .044 and there is no difference between “stock” or “factory” they are the same.
