Speedo Cable ? with cable/hydro conversion
I found a good deal on a gsr tranny, and didn’t know if i the hydro convrersion would i still be able to keep my speedo. Because isn’t the gsr one electric and not a cable one like in the DA integras. ANy help would be great
you can put the cable one into the hydro trans
He means the actual speed sensor, slides right out and in the hydro tranny no problem.
He means remove the 1 10mm bolt that holds down the the VSS then slide it out and replace with the one that was on your original motor. Careful with that bolt. I over tightened mine and broke the VSS bracket.
