speedo issue
hey guys, long time since i posted on here but im having some issues with my 91 ls… i was driving home yesterday when all of a sudden my speedo droped to zero and my check engine light came on… everything else was still working. Could this be a bad vehicle speed sensor? or something else. bad cable maybe… i dunno… any ideas.
thanks
Well why don’t you check and see what CEL code it is throwing first? That would be the most common sense thing to do if CEL comes on. :think:
i already know its the vehicle speed sensor (code 17) i was asking if it could be a bad cable or the vss went out.
well looks like it was a good thing something like this happand. turns out i also have a busted cv joint… does anyone know of a online manual… i need to make sure my vss is put back together right.
If you’re vss attach leg is busted andthe gear is lifting out the trans then, I’ve got a 25 cent fix.:angel:
i found the problem. the cable itself is busted. so i need a new one… now i have the great task of ripping my dash apart to fix this damn thing…
When you get to the boot that covers the clip on the speedo gear, cut a small slit on the bottom edge. That way you won’t rip the crap out of your knuckles trying to get that back on. It’ll be a simple twist action and your done.:slight_smile:
