Speedo!
This moring got into my car and noticed my mph isnt working:( but i noticed i lauched my car a little and it started t work agian … now i went on lunch and drove its not working again do i need new tach?
the speedo cable plugs into the top of the tranny. Can you check that end? its better then taking out the dash cluster
Check the speed cable and sensor located on the transmission
alright thanks ill check after work.! will i have to lift or can i reach from engine bay>?
Pop the hood and look down by the fire wall and you will see it.
look at a diagram and you will see the clip that holds it in (if you have not seen it before). You should not be able to pull out the speedo if the clip is in. if you pull the speedo out, then that clip holding it in place came out.
REd is where the cable slides in to.
Green is where the clip is. It holds the cable in place.
Black is for the oil hoses. The gears inside makes a pumping action and pull oil threw one and out the other.
Blue is is where a 10mm bolt holds the sensor to the transmission.
Yellow is the part that go’s in the transmission housing.
chances are the speedo cable isnt all the way pluged in. that happend to me the other day when i put my new speedo cable in. with worked fine for a while. but when i launched hard it was about 50% off. and then quit working entirely. turned out i didnt have it pluged in all the way.
bored at work desk job lol went out and pushed it in works fine now… im wondering tho will i be able to see the clip ? that holds it in also when i pushed it in the cable made click noise like it was gonna stay in place so not sure if clip is there or not.
hard to see it when its clicked in. that was it. it clicked in.
