So I just purchased a GSR cluster from a member here and it occurred to me that there may be different calibrations for the two clusters. So I did a little research and this is what I found, the GSR Speedometer component is different compared to an LS one. Yet they have the same power steering /vehicle speed sensor.
Speedometer
GSR: 78120-SK7-A21
LS: 78120-SK7-41
VSS
GSR/LS: 56500-PR3-010
I also looked at the differences between the Tachometers, they are different, obviously, cosmetically yes but mechanically? Who knows.
GSR: 78125-SK7-A91
LS: 78125-SK7-A12
So until I receive my GSR cluster I won’t know for sure, so in the mean time I need some assistance. If you have a 90-93 GS/LS/RS with a 92-93 GSR cluster what is your RPM reading at 50 MPH? Also if anyone has an open cluster with the speedometer part out, look on the back of it, there should be a number like 1258rpm/km or something like that. This should be the calibration number used to match the gearing of the car to the speedometer, I am curious if these are the same or not.
Once I open these two up in the coming weeks I will let everyone know my findings.
They are different part numbers because they are different parts! The Speedometer / odometer is silk screened with “premium fuel only” on the GSR the LS does not have this. The tach is also different due to higher RPM on the GSR.
Ahh yes I forgot about the premium fuel on the speedometer.
Well I know it is plug and play its the differences in RPM that I am worried about. By my calculations I get a 72 RPM difference between the GSR and the LS because of final drives. Also it is interesting to note that the GSR/LS have the exact same differential part, which also means they have the same gear to drive the VSS.
Differential:
GSR/LS/RS/GS: 41100-P21-000
So that means the only difference is the final drive and the speedometer. My hunch is that the speedometer is calibrated for the 4.4 gearing and by putting it in the LS with 4.266 gearing you will be at 72 higher RPMs and thus be speeding.
The difference is small yes, but its a 1.6 MPH difference, and a 72 RPM difference by my calculations. But I still have to test that.
Ok so I was thinking backwards with respect to this whole conundrum of mine. I was falsely assuming that the final drive affects what speed you are at, true for an RPM dependence; not so the other way around.
Let honda-tech learn us all.
So I think we can all agree that the differences are purely cosmetic.
