Speedometer slow
Just put a new speedo cable in cause it went bad, but now the speedometer moves up and down very slow. What can I do to fix it, just pull it out from the tranny end and add more grease?
Thanks,
Coz
I think your just to fast :(…lol jp jp… yeah try to grease it up n make sure its not loose - DOFL-FAVA
If it was a brand new speedo, then the lube inside the cable should be fine.
Sounds like one of the ends isn’t seated quite right. You may want to remove it and try again.
Brand new speedo cable, yah. Ok I’ll try that when it warms up a little, we got this crazy cold front that hit the last few days.
Thanks.
Coz
