Spring/Shock rates
What rates should a da6 have
I have 500lb in the front and 400lb in the rear on my pro1 coilovers
using bilsteins all round my car is sooooo stiff and at 60MPH when i weve left and right the rear lags and follows after the front
so in effect the car twists, it’s dangerous
I am trying some softer springs in the rear sometime this week
I would guess that your problem would get worse with softer rear springs.
The rear lagging the front is always going to happen since only the front wheels are steering. What’s your alignment like?
yeh i thought softer would be worse but mechanic seems to think the oppisite
yeh it lags really bad and chassis feels like it twists
my allignment is spot on, this has been a prob for about a year and I can’t fix it
tried replacing all rear bushings but still it twists
Well, I’m not saying you have to trust me, but I would suggest against taking your mechanics word. They usually don’t know much about vehicle dynamics.
If you have a a really thick rear sway and no front sway (or a small one) you may get more than usual “twisting”. I’ve never heard of such a problem on a unibody Honda.
the place that recommended this has been involved with hondas for many years, raced them and builds drag cars
yeh I have front and rear strut braces, nolthane bushings in rear
shocks are bilsteins all round, the fronts are shortend bodied DC2R spec
and rear is DC2 spec
I had to modify front forks to fit em
the car handles well at slow speed but once over 60MPH the body twists
the car is VERY VERY stiff, too stiff maybe twisting the chassis
I am gonna try to raise the back up 10mm and see if it helps it at all, taking some load of suspension. then i will put the 200lb springs in that he lent me
Well try the softer springs, and if it reduces what you’re talking about, tell your mechanic that I’m sorry. :cross:
I asked about your alignment, because a “rotation-prone” alignment can make the car try to rotate with quick steering input. I see that with Azenis on my car.
yeh thats what happens to me a quick snap on the wheel makes the car chassis twist
so any more ideas? i have had like 3 alignments at different places
Align the car yourself:
Read and follow links in original post
Saves money and you know it’s getting done right. Computerized (but not particuarly laser) alignments are total GARBAGE!!!
Use the factory settings (available in any Service Manual) as a reference and go from there. You might be able to track down your problem through trial and error w/ different settings.
Well when I meant “rotation” I mean car tries to spin out. When you say “twist” you mean that the front rolls and the rear does not, correct?
no rolling
twisting
front stays and rear twists, no body roll cause my car is really stiff
it bends in realtion the the front wheels, as if the trailing arm bushes are goje, except i replaced those with after market ones
