is a 1.75-2.00 in drop alot…does it leave any gap…i want it to be perfect with no gap with 15 inch rims…how much should i lower?
gonna need more then 2
2.5 probably and even that is some gap on some cars depends on your tires
Your car is going to suffer from lowering 2.5". Plus, with 15" wheels, tires the slightly larger sidewall will make whatever gap you have appear larger because there’s little contrast.
To answer your question, 2.5" with 205/15 15s will reduce about all of the gap.
