Sqeaking noise from the rear!
i have this squeaking noise from the rear, i needed rear shocks so changed them, but the noise is still there! what is it, and how can i fix it please help asap
try using that rattle method in teg tips and see if it holds the trunk tighter. if its not that then those hatch pistons needs some greese. also it could still be your suspension settleing in.
my front drivers side squeaks from suspsension and its well set in…
Wonder if its the same prob?
It just started doing it about a month ago and never did it before (same suspension 8 months)
Chado
do a search i think i read somewhere that u put this kind of greese or something like that on the spring or something IF it is the suspension.
rear trailing arm bushings dry! Get the shim kit at acura for about 5-10$cnd! It was a service letter for 92-93 tegs for rear susp noise you must lube with silicone grease+install shims youir squeek will be gone if it is rear suspension noise
Camber kits also squeak…
