i’m experiencing a squeaky noise once car is rolling, the squeak does not come on when parked… Thought at first it was my alternator but after replacing it the noise did not go away… changed the power steering belt and alternator belt as well… the squeak gets louder if the car starts running faster, What could this be? need help and input? thanks…
Brakes?
A\C belt?
Rats?
I thought brakes don’t squeak until you step on em? in my case the squeak is constant if the car is rolling…
I have no AC in the car…
as of Rats? their seem to be none at the moment… no rats…
Does the squeaking stop when you hit the brakes? if so the pads should have squeakers on them that will squeak when the pad gets low and itll go away when you hit the brakes. if the squeaking stops when you hit the pedal, at least take the wheels off and check the pads.
i get similar squeaking sound
this is after we had floods here and i drove over a deep puddle
now it squeaks a lot when i turn the steering to the left and sometimes when goign over bumps.
