I know must of you are going to say bad belts but its not.
It does not happen at a stop or when I first turn on the car.
The sound is SPEED dependent, the faster I go the fasted the squeal sounds.
I checked tire clearance and it definitely doesn’t rub on the fender or inner wheel plastics.
Could it be a wheel bearing? Does the mid-shaft have a bearing that could be going out?
Those are my two thoughts, if anyone has experienced anything like this let me know what you did to correct the problem.
Thanks.
