Squeeling noise while pulling out of 1st, sometimes changing gears
Almost every time I’m idling and i start out in first, while I’m letting off the clutch and accelerating my car usually makes a loud squealing sound, It also will make the squeal while shifting through gears (sometimes) I’m thinking it could be my throwout bearing but I’ve had a lot of people tell me throwout bearings make a slightly different noise. I haven’t taken apart anything because i know a throwout bearing is a pain to repair. I don’t want to go for it and end up it being something else. I’ve looked at videos online of throwout bearings and my problem doesn’t seem to be the same. If needed I’ll take a video asap.
If any advice to what it could be would be helpful, thank you
It could be the pilot bearing. I had a pilot bearing sieze on me once causing the input shaft spin on the inner race. It made a horrible metal on metal squeeling noise that sounded like a VERY loud belt squeel. It did the same thing as yours. It would squeel especially bad in first and when I pushed in the clutch to change gears.
Hmm, i never thought about that. Thanks for the thought, I’m about to upload a video in a bit.
http://www.youtube.com/watch?v=5fHBzC0_QlA
Its not letting me directly put the video in here, so theres the link to it. Please check it out and reply, thanks.
Nothing?
It is similar to the noise I had experienced with the pilot bearing, but I don’t think that is it. If it were the pilot bearing it would probably make noise even while idling (as mine did). I actually just changed my clutch (including pilot and throwout bearings) the other day and the TO bearing was starting to squeal a little bit. The noise I was hearing was a little bit higher in pitch than yours, but very similar. It’s hard to say man. But I would say a bad TO bearing is possible. How old is your clutch? Usually a new TO bearing is included in new clutch kits. If yours is old/worn out it might be a good oportunity to eliminate the TO bearing as a possibility.
