So these are somewhat multiple problems…
I tried starting the car a couple times and it wouldn’t start right away, it’s sputter a bit but wouldn’t stay started. finally it would start up and idle normal. but sometimes, it will die if I give it gas, or sometimes idle will slowly drop and even if I pump gas, it just dies.
sometimes, idle is normal, and I can give it gas no prob, other times, it fucts up.
Also, sometimes fuel pump doesn’t prime, sometimes it will and it’ll start
other prob…
car starts very strong (good power to starter) but my headlights and everything are dim, and I have low power to most everything.
My ides so far…I’m pretty sure it’s fuel related…
Main fuel relay? am I not getting enough power to my pump and relay?
Alternator?
I have a TPS code, but I’m pretty sure that wouldn’t make a difference. it just needs to be adjusted.
all my grounds are good
I"m clueless :rant:
