my electrical troubles continue… it was starting fine before, now the starter ground is bad again. i had regrounded it and it was working fine…now it started to spark again…whats goin on?
all the wires are grounded properly…i tore apart all the wiring looms and there are no problems with the wiring…i hate this f%cking electrical system!!! could there be a problem with the ignition switch???
here is a list of the stupid things its doing:
-turn the key to accessory, temp guage goes up
-hit brakes, temp guage goes up
-turn on headlights, engine stumbles and shuts off (when it was running, now it doesnt even crank again)
-turn on turnsignal and hit the brakes, turnsignal goes off
-turnsignals make dash lights blink, along with clock
-horn dims all lights
-turn on driving lights, temp guage goes up
theres more but thats all i can think of off the top of my head…what the hell is going on???
just checking, all the big ground wires are connected right? the one on the valve cover, on the tranny, on the body? One of thoses missing would cause all sorts of weird problems!
BTW, was the car running great prior to the B20 swap?
all the grounds are good… and it was running ok before the swap, except for the fuel relay that i replaced…i have no clue why all this stuff is happening when it was such a simple swap…
all i know is that someone messed with all the wiring in the car and it was bound to happen sooner or later
i have sunk to my lowest…the car is going to the dealer tomorrow for them to fix the electrical system :mad: :argh: :down: :vomit:
