starter mounting bolt size
can anyone tell me the size of the lower mounting bolt for the starter. It is a differnt size then the upper mounting hole. The manuel i have say that they are both the same size but they are not.
I would like to know also since I’ve put together my spare engine 2 years ago I’ve been rolling with the top bolt on the starter. Never found the bottom and never really bothered me and I know I can continue with the top bolt only without any negative effects.
M10x40mm top and M10x105mm bottom.
The bottom one goes all the way through the GB housing and into the block
Ive been riding with just the top bolt, this is the second start i go thru because the housing of the starter keeps cracking i guess there’s to much vibration in my engine
[QUOTE=mooshie;2320519]M10x40mm top and M10x105mm bottom.
The bottom one goes all the way through the GB housing and into the block[/QUOTE]
thanks mosshie, gonna look for that bolt
