starter relay?
please help…does anyone know EXACTLY where the starter relay for a 91 teg is.
up behind the dash. just right of the stereo…have fun
if you drop the straps to the AC components under the dash, you can move it all out of the way just enough to go at it through the hole in the dash that youll have when you remove the glovebox…
you might need an angled screwdriver to remove the screw. you can just barely see the screw through the removed glovebox hole.
also, dont be confused, there are two black boxes right there next to each other, the starter relay is the smaller cube shaped one with the square shaped connector. heres a tip too: when you reinstall it, it doesnt have to go back where it was mounted. you can mount it anywhere the wires will reach, making it a lot easier to replace/diagnose issues in the future.
