as i started my car after work today it didn’t want to start, it would turn really strong so nothings wrong with the battery. after trying and trying for 10 minutes it finally started. this happened once before after work…both times were after a long hot day…what could be the cause of this? not getting gas…?
When is the last time you did a tuneup?? That could be your problem right there.
If it is cranking strong then it is most likely fuel/ignition related…
Later,
BR
With the problem you are having, these are the things that I would check out…
Overheated or faulty coil
Clogged Fuel Filter
Fuel Pump on it’s way out
Contaminated Fuel (bad tank of gas)
Best of luck.
i have that problem too sometime when the car sits in the sun for a while…i hear that its the fuel relay under the dash that causes this problem
