steering lock removal?
Hi guys I have a couple ideas I need confirmation on before I go through w it. My ignition is getting quite loose that when I drive the air will shut off and I have to play w the key to get it to turn back on. This would not be a big deal to me but it also causes my brake lights not to work my question is how to I remove ignition and steering lock I wanna do two switches in coin holder for acc and on then put a push button in place of key on column is this possible? Thanks all I can’t find how to remove steering lock but have found how to install a pushbutton.
The ign. switch has nothing to do with your brake lights.
If you have an ign. switch problem, [common on older Honda/Acura] replace the switch…
A few screws to access it, two to remove it, some plugs and your done.
Your brake light problem is most likely a problem with the brake light switch. 94
Generally yes it wouldn’t but its an auto converted to manual and how Its wired it effects my lights not sure how previous owner did it but thank you for the advice I figured it was mechanical just how the key was loose and you would have to turn it just right for everything to work. Also read a grounding issue could have similar effects will be looking at them as well.
