my wheel started squeeking the day i put my cf steering wheel on… turned out that the round cruise controll thing that goes behind the hub was rubbing the hub… whiped out the disc sander and problem solved… as for the gas pedal, jus spray a good lubricant on the return spring and you should be as good as new.
