No, I’m not driving a Toyota. It’s a 92 Integra RS. Ok, here’s the problem. When I release my foot from the gas pedal and reapply it, it requires a little extra push at the very beginning of the acceleration. This causes it to jerk slightly, which is very annoying when I drive.
I have peeked my head down there to see whats going on and to apply some lubricant to loosen up whatever could be sticking. Here’s what I saw. The mount that is attached to the floorboard is bolted in securely, but the gas pedal is a little loose where the rod goes through the mount. So when I step on the pedal, it tilts sideways very slightly and then begins to pull the accelerator cable.
My questions are: Are there suppose to be any plastic grommets fitted inside the holes of the mount where the rod goes to tighten it. Are there any cool aftermarket replacements?
