stoped chirping 2nd gear! why?
used to chirp 2nd gear all the time, now it doesnt anymore. could i be my motor mounts, i have a feeling my rear motor mount is shot along with some front suspension bushings but could this be the cause?
  1. This is not a help forum.
  2. Stop trying to chirp your car,its not good to do so.
  3. Because you keep on trying to spin the wheels,you’re clutch might be slipping now.
  4. Learn to drive the car the way it should be driven and you’d have no problems.
Sorry if i sound like a dick to you but use commonsense
clutch is wearing down, engine is losing power, or could be something much simpler like the clutch cable malfunctioning.
Oh noes!!!
Your clutch fluid level must be less than half way… refill it to max and you’re good to go. With full clutch fluid level… you can sometimes chirp in 6th gear if you put your mind to it… good luck!
What are you talking about? Our cars are cable driven clutch. There is no clutch fluid needed
Nor do they have a 6th gear…
sarcasm > you
check your fluxcapacitor maybe its not fluxing right.
[QUOTE=wearedaughters;2135714]Nor do they have a 6th gear…
sarcasm > you[/QUOTE]
I know that. They have 7. But our cars have what you call a clutch VTECH cable as well:werd: And yes, check your fluxcapacitor. That might be the problem.:giggle:
agreed check the fluxcapacitor and why worrie about 2nd 3rd gear burnouts is were its at…oooooooo Idea put a big a** wing on the back then your good to go :ethug:
