Okay so I found a badass brake kit made by Stoptech on jhpusa.com. However it doesn’t have it available for the 90-93 Integra. Will the kit for the 94-01 Integra work?
From what I’ve seen, when a part says only 94-01 and not 90-01 it means it will only work for generation 3 tegs but I can’t say for sure. Call and ask 'em or call Stoptech… if they can’t give you decent tech support maybe they’re not worth buying from.
should work, just should have to cut the dust shields a little bit… alot of guys run type r calipers and stuff on their da. just not a direct bolt on, as with nsx and type r calipers u have to run 05-06 mini cooper non type s rotors.
