strobes when e brake is on only
ok i have strobe lights on my car. i dont know why dont ask. but i want to know is there a way i can ground it so the strobes will only turn on when the e brake is on? kinda like a dvd player. the last thing i need is impersonating an officer
Yes you can, make the ground connection right at the Ebrake switch in the console, not the the lead that comes from the switch.
You may also have to install a diode on the Ebrake line to isolate the brake still on warning light and the strobe.:hmm:94
wow im lost lol im a newbie.sorry. but where can this place be founds for the connection
Under the console, attatched to the Ebrake or it’s mounting bracket, there is only one, single wire, plug plugged unto the switch, easy to see once console is out.
With that said, pulling the console is not easy, I should say it’s not hard, just time consuming, lots of stuff has to come apart, be careful do not forget to remove the 2 screws above the HU, that’s what most guys brake.:idea: 94
