So yesterday I had my car apart doing some work, I decided the pcv valve would be an easy thing to do. Long story short, it came out bits and pieces at a time, now theres just the hose from the breather box with no valve / vacuum applied to it, I just capped off the vac line from the manifold for now.
Do I have to pull the manifold now to reach the black baffle box and run a new hose? It was nearly impossible to get to from below. I’m thinking about just throwing in a catch can now…
same thing happened to me… you can raise the car up and just struggle with it from underneath so you dont have to take off the manifold and run the risk of if you put something on wrong its going to idle funny or poor mileage…i went by lifting the car and just taking off the line. just make sure to get the hoses from acura dealership, i think i got the line that broke, the pcv valve and the hose from the pcv valve to the intake manifold for 60 all together
