As you see, my DA is my daily driver im looking to get some new wheels and tires, looking to tuck/stay with flush look without CRAZY camber (i.e. 0 offset ect.)…
I need to know recomended tire/offset for 16x8 wheels
**If im headed in the right derection let me know, I wanted to get some 16x8 +20 wheels with a 195-50-16 tire
BTW my set up is capable of adjusting, i have full adjustable skunk2 coilover suspention front and back with adj camber kits
IMO, 195’s would look too stretched. I’m rockin’ 16x8 +20 Rota Grid Off Roads myself, and I absolutely love them. At first, I mounted 205/40/16’s. Everything fit right. Camber was set at 0, and no need for fender rolling. The only problem I had with them is that they looked like baby wheels inside the wheel well. I then mounted 205/45/16’s and it looked much better. Had to do a little fender rolling but very minute. Also, I’m sitting on Tien S tech springs.
^ this should help you out/give you some ideas.[/QUOTE]
They don’t give camber numbers though. He’s looking to minimize camber and seeing some of those numbers on offset you would have to camber.
215/45/16 rear 205/45/16 front… thats what i would suggest… im running that setup on 15’s and it looks pretty good… slightly cambered in rear with no camber kit and more cambered in front due to skunk2 camber kit…
